Executing a Panel "dropdown" list item
isocam
isocam
Can anybody help?
I have created a toolbar, using a Fusion 360 Python script, that has 4 separate dropdown options.
Please see the attached txt file for the code that I am using to create the toolbar.
How can I run the code associated with each dropdown item?
For example,
The first dropdown item is called "Configure".
For testing purposes only, I want to show a messagebox saying "You have selected "Configure" when I manually select it from the dropdown list.
Many thanks in advance!
Darren
zxynine
Your command definition object you got when you created the button definition is what you use to first start handling events. The def has a commandCreated event you will assign a handler to which will fire whenever the user selects that button. See this page on info for command definitions. You seem to be newer to commands in the api, so i highly suggest reading through the documentation as itll help a ton. Heres the page on events which should get you started with that.
