Execute command without selection input defined
J.M.MAY
J.M.MAY
Hi guys,
I want to set up a command for the UI with several optional inputs. I have BoolValueCommandInputs, StringValueCommandInputs and so on. But as soon as i add a selectionCommandInput, the OK-button in the dialog is grayed (as long as there is no selection done) and can't be clicked. I'm wondering, how to execute the command without the selectionCommandInput - or in other words how to define the selectionCommandInput as optional?
Thanks for your help in advance!
nnikbin
You can use SelectionCommandInput.setSelectionLimits Method with minimum argument set to 0. For precise control you can use ValidateInputsEvent Object.
