Error when reading rotationValue
I am trying to change the angel of a simple revolution as BuiltIn joint like this:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        occ = root.occurrences.itemByName("MyComponent:1")
        ui.messageBox(occ.name)
        driveJoint = occ.component.asBuiltJoints.itemByName("Rev7")
        revMotion = adsk.fusion.RevoluteJointMotion.cast(driveJoint.jointMotion)
        somevar = revMotion.rotationValue
        revMotion.rotationValue = somevar
        ui.messageBox(revMotion.rotationValue)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The problem is that I always get an error when trying to read the value of `rotationValue` like in this line:
Fusion 360
Failed:
Traceback (most recent call last):
  File "C:/Users/XXX/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Simulator/Simulator.py", line 22, in run
  File "C:/Users/XXX/AppData/Local/Autodesk/webdeploy/production/e93c21ea16478b49c4dee1f65accf1a11ae6ef96/Api/Python/packages\adsk\fusion.py", line 50025, in _get_rotationValue
    return _fusion.RevoluteJointMotion__get_rotationValue(self)
RuntimeError: 2 : InternalValidationError : axis
OK
Could anyone help me to get rid of this error? I cannot understand totally why this is happening..
What I am trying to achieve is getting a relative motion, so just to increase the current angel like this:
    revMotion.rotationValue = revMotion.rotationValue + 1
kandennti
Hi @Anonymous .
Isn't driveJoint set to None?
driveJoint = occ.joints.itemByName ("Rev7")
How about changing to?
Hello, actually noy because I am able to move the joint when I write an explicit value to the rotationValue, but reading it causes the error.
kandennti
I ran the following code with the model data in the attachment.
I couldn't reproduce the situation.
def run(context):
    ui = None
    try:
        driveJoint = occ.joints.itemByName("Rev7")
        ui.messageBox(str(revMotion.rotationValue))
    except:
        if ui:
