Edit grid spacing in Fusion360 through API
Is there any way to get access to grid settings in order to fix the grid and change grid spacing, like in grid and snaps programmatically using the API?
kandennti
Hi @Anonymous .
I created a sample that changes the grid.
#Fusion360API Python script
import adsk.core, adsk.fusio, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        # grid setting
        setGrid(2,10)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# majerGridSpacing - unit Cm
def setGrid(
    majerGridSpacing :float,
    minorSubdivisions :float
    cmds = [
        u'NuCommands.DefineGridCmd',
        u'Commands.SetDouble GridSpacingInput {}'.format(majerGridSpacing),
        u'Commands.SetDouble GridsubdivisionsInput {}'.format(minorSubdivisions),
        u'NuCommands.CommitCmd'
    [app.executeTextCommand(cmd) for cmd in cmds]
For more information on how to use TextCommands, see here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands2/m-p/9937161
@kandennti thank you for your response, do you know about the TextCommand for fit with the shortcut F6? I tried '
Camera.ZoomOut' but it isn't that accurate. Do you know the command for Fit in the zoom window?
