Dynamo Script to Remove a Body or Component
Hi, I am currently using Dynamo for Fusion 360 to automate changes in size for bulk material bins/hoppers. I am currently looking at a rectangular bin that could have either single or dual outlets (see screenshot below showing both options overlapping). I am creating this as a shell model so I can use it as an import to an FEA package. I have set these up so that an excel sheet inputs the dimensions to dynamo which then feeds them to the appropriate parameters, processing some of the parameters on the way. I am wondering if it is possible to have an item in the excel sheet where the user selects between single or dual outlets and then, based on that input, the dynamo script deletes either the dual or single outlet hopper shells accordingly.
Thanks in advance for any assistance.
goyals
I am not sure I understood the question very well. There is one add-in, https://apps.autodesk.com/FUSION/en/Detail/Index?id=1801418194626000805&appLang=en&os=Win64, written over Fusion API to export the parameters of a design in to excel sheet. Later you can change the parameters value in excel sheet and import it back in Fusion and new values will be applied on the design.
Shyam Goyal
Shyam Goyal
Sr. Software Dev. Manager
