Dropdown ListItem does not support strings with german characters like "Ä,ä,Ü,ü,Ö,ö and ß".
manfred_weinert
manfred_weinert
It is easy to reproduce this issue.
Create the c++ "Command Input API sample" and run it.
You will see the window above.
Now stop  the AddIn.
Modify line 384 of the c++ source Code from:
dropdown4Items->add("Item 1", true, "");
to:
dropdown4Items->add("Item 1 Länge", true, "");
Länge is the German translation of length.
Create a new dll for the AddIn and execute it.
You will see the window above. only an empty line is shown for the ListItem.
Can anybody help here?
Best regards
Manfred
MichaelT_123
Hi Mr Manfred_Weinert
Check how Unicode characters are handled on Windows.
Keywords to check are:
  • Unicode
  • UTF-8
  • wchar_t vs char
  • std::wstring vs std::string
  • codepage
Regards
MichaelT
MichaelT
manfred_weinert
Hello Michael,
the issue was more depending on the incorrect setup of the development environment of Visual Studio 2022.
The following links helped me to fix the issue:
https://learn.microsoft.com/en-us/cpp/build/reference/utf-8-set-source-and-executable-character-sets...
https://learn.microsoft.com/en-us/visualstudio/ide/how-to-save-and-open-files-with-encoding?view=vs-...
Regards Manfred
