Document Opening Class - Does Not Work With Drawings
isocam
isocam
Can anybody help?
The following Fusion 360 Python "Class" works OK when opening an assembly, or a part, but does not work when opening a drawing.
class MyDocumentOpenedHandler(adsk.core.DocumentEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
global app, ui
ui = app.userInterface
design = adsk.fusion.Design.cast(app.activeProduct)
document = design.parentDocument
ui.messageBox("DOCUMENT OPENING", 'Fusion 360', 0, 3)
Does anybody know how to modify the code so that it also works when opening a drawing?
Many thanks in advance!
Darren
Rushikesh.kadam
@isocam for drawing file the design object is returned as None. An error occurs for the line document = design.parentDocument. Hence the message box line is never executed.
Here is the modified code which worked for me.
    def __init__(self):
        super().__init__()
        try:
            global app, ui
            if design is not None:
        except:
            app.log('AddIn Stop Failed: {}'.format(traceback.format_exc()))
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
