Determine Whether a Project is Saved or Not
Siff3D
Siff3D
Hi All,
I'm looking for a way to determine whether the current project is saved or not. By "saved " I mean that the "Save" button was pressed and there is no "*" displayed next to the project name.
I tried using the Document.IsSaved property (https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-6beff12d-3287-4cd8-a9bb-e6da2a066c01), but it is set to False only if the document is brand-new and was never saved and it will be set to True after the first Save (which should be Save As...).
Thank you!
BrianEkins
You want to use the Document.isModified property. It indicates if any changes have been made since the document was opened or last saved.
Brian Ekins
Siff3D
Thank you @BrianEkins!
I don't know how I missed it! I checked all properties several times, but apparently, I glazed over isModified since it it right above the isSaved property! 😥
