Determine if document is a "Part" or a "Assembly
isocam
isocam
Can anybody help?
Is it possible, using a Python script to determine if the document that is opened, is a "Part" or an "Assembly" and show this in a message box?
Eg
The document is a Part
The document is a Assembly
Many thanks in advance!
Darren
kandennti
Hi @isocam .
I interpreted this as determining if Occurrence had a link.
You can use the isReferencedComponent property to determine this.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-6D3CD4ED-570D-433D-97AD-EB110DA94177
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        for occ in root.allOccurrences:
            print(f'{occ.name} : {occ.isReferencedComponent}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
BrianEkins
Fusion doesn't differentiate between a part and an assembly, so it's up to us to define what a part or assembly is.
The pure definition is a part is a component that only contains bodies and not any occurrences.  An assembly is a component that only contains occurrences and no bodies.  Anything else is some kind of a part and assembly hybrid.  Here's some code that determines this.
def determineDocumentType():
    try:
        app = adsk.core.Application.get()
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        if root.occurrences.count > 0 and root.bRepBodies.count > 0:
            ui.messageBox('Document is a hybrid of assembly and part.')
        elif root.occurrences.count > 0 and root.bRepBodies.count == 0:
            ui.messageBox('Document is an assembly.')
        elif root.occurrences.count == 0 and root.bRepBodies.count > 0:
            ui.messageBox('Document is a part.')
        elif root.occurrences.count == 0 and root.bRepBodies.count == 0:
            ui.messageBox('Document is an empty part.')
    except:
        if ui:
Brian Ekins
