Detect when the CAM Simulation environment is on
ltomuta
Advisor Advisor
ltomuta
I would like to hide/show a palette when the user starts/ends a CAM simulation but I could not figure out a way to be notified of the change. Any idea?
jeff.pek
Hi -
You can probably use command execution events - https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051#Execute... - to detect the launch of the command that opens the environment, and the event that closes it.
The launch command IDs are "IronSimulation" and "IronMachineSimulation". The "finish" command is "SimulationStop".
Jeff
ltomuta
Worked like a charm. Thanks @jeff.pek !
kandennti
Hi @ltomuta -San.
If you want to check in the middle of some process, you can check if ToolbarControl is displayed here.
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        print(is_cam_simulation_working())
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def is_cam_simulation_working() -> bool:
    ui: core.UserInterface = app.userInterface
    panels: core.ToolbarPanels = ui.allToolbarPanels.itemById(
        "SimulationFinishPanel"
    controlLst = filter(
        lambda c: c.id == "SimulationStop", panels.controls
    return list(controlLst)[0].isVisible
