Design to code
Design to code
malmosa2
Design to code
malmosa2
I know that I can use the add ins and fusion api to use scripts, but I just completed a project, and would like to know if I can convert my whole design into a code that describes everything I completed sequentially. Basically like the opposite of what the running the script does ( turning design into code, instead of code into design). Is that currently possible? or are there any plans to implement such a feature?
kandennti
Hi @malmosa2 -San.
As far as I know, there is no feature you want directly.
It might be possible to create it if you went through the timeline in order and looked up the functionality of each feature, but it would require a lot of effort and time, and would not be realistic since not all the functionality is likely to be provided by the API.
