Delete multiple sketches
dinocoglitore
dinocoglitore
Hi all, I am looking for a better way to delete multiple sketchs with only one or few instructions.
Actually I follow a simple method using a loop but I hope that exist a more efficient way using some Api method.
This what I do (I am a newbye so please excuse me !)
sketchArray = []
# in a loop I create sketches with assigned names:
sketchPlane.name="SK-"+str(k)
# append name in an array
sketchArray.append(k)
sketchArray[k] = sketchPlane.name
#in another loop (after I use all the sketches) I delete the sketches
for k in range(0,n):
  sketches.itemByName(sketchArray[k]).deleteMe()
Many Thanks
Dino
liujac
You may add a sub component under the root component and add the sketches to the sub component. Just delete the sub component at the end.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComp = design.rootComponent
        transform = adsk.core.Matrix3D.create()
        occ = rootComp.occurrences.addNewComponent(transform)
        subComp = occ.component
        sketches = subComp.sketches
        for i in range (0, 100):
            sketches.add(rootComp.xYConstructionPlane)
        occ.deleteMe()
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
dinocoglitore
I thank you very much.
You answered  my question in a very elegant form. I will implement you solution in my script writing that you are the author so I can remeber how far is my knowledge from a correct way of using API.
Many thanks.
Dino
