Custom Feature API Preview - Feedback Thread
prainsberry
Autodesk Autodesk
Message 1 of 84
prainsberry
Fusion 360 Custom Feature APIFusion 360 Custom Feature API
With the release of Fusion 360 today, we are very excited to announce the availability of a preview of the new Custom Feature API.  This is a long-awaited capability for the Fusion 360 API and our first iteration is now available.  Please note we are considering this “Preview” functionality as there are some limitations and only some specific workflows that we support.  That said this a MAJOR enhancement to the Fusion 360 API.
You can now not only define a custom command dialog for your add-in, but you can actually define it as a full feature definition.  This means that parametric timeline updates, model parameter changes and user edits will all now behave as expected for any other feature in Fusion 360.  There is a lot of information to digest for this one, so if this interests you, check out our help documentation and learn more about this functionality.
We would love to hear more about how you would like to use it, what you have built, or would like to build.  We would like to use this thread to capture feedback about the current capabilities, as well as what you would like to see next.
Patrick Rainsberry
Developer Advocate, Fusion 360
Replies (83)
Message 81 of 84
markSJVQS
I am having the same issue when combining bodies in different components.
The `CombineFeature` gets created in the parent component of the target body and not in the component where `component.features.combineFeatures.add(input)` is call on.
This then causes an error when creating the `CustomFeature` because the child features are in different components.
Is there a way to work around this?
Message 82 of 84
RubyRedRick
I'm trying to write a custom feature based on the CustomPocket example.
The goal is to make something like the hole tool but to make pockets for heated threaded inserts in 3d prints.
I'm to the point where I just can't understand the geometry.  Here are some screen snapshots In the code I'm doing the combine as a join so that the insert body is visible. Once I get this straigened out it will be a cut.
The first screen shot is an isometric. view showing the selected point and the generated body{
Then we have  a front view showing that the body is too hing and to the left.
Finally a top viww showing that the body is too far forward:
This is the function to generate the tool body.  I've also attache the whole extension directory as a zip file.
# Utility function that given the position and pocket size builds
# a temporary B-Rep body is the tool body to create the pocket.
def CreateThreadedInsertBody(point, a, b, c, d😞
try:
# Get the face the point is on.
face: adsk.fusion.BRepFace = GetFaceUnderPoint(point)
if face is None:
return None
# Define the pocket at the origin with the length in the X direction,
# width in the Y direction, and d in the -Z direction.
tBRep: adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
lengthDir = adsk.core.Vector3D.create(1, 0, 0)
widthDir = adsk.core.Vector3D.create(0, 1, 0)
bodies = []
aRadius = a / 2.0
bRadius = b / 2.0
# X is 44.762 too high
# Y is 27.622 too high
# Z is 44.925 off
coneNadirPoint = adsk.core.Point3D.create(point.x, point.y, point.z - c)
nadirPoint = adsk.core.Point3D.create(point.x, point.y, point.z - d)
cone = tBRep.createCylinderOrCone(
point,
aRadius,
coneNadirPoint,
bRadius)
cylinder = tBRep.createCylinderOrCone(
coneNadirPoint,
bRadius,
nadirPoint,
bRadius)
bodies.append(cone)
bodies.append(cylinder)
# Combine the bodies into a single body.
newBody: adsk.fusion.BRepBody = None
for body in bodies:
if newBody is None:
newBody = body
else:
tBRep.booleanOperation(newBody, body, adsk.fusion.BooleanTypes.UnionBooleanType)
# Get the natural U direction and normal of the face and use them as the length and d directions.
eval = face.evaluator
(_, param) = eval.getParameterAtPoint(point)
(_, normal) = eval.getNormalAtParameter(param)
(_, lengthDir, _) = eval.getFirstDerivative(param)
widthDir = normal.crossProduct(lengthDir)
# Define a transform to position the pocket body onto the part.
trans = adsk.core.Matrix3D.create()
trans.setWithCoordinateSystem(point, lengthDir, widthDir, normal)
tBRep.transform(newBody, trans)
return newBody
except:
showMessage('CreateThreadedInsertBody: {}\n'.format(traceback.format_exc()))
Message 83 of 84
markSJVQS
I noticed that CustomFeatures cannot be edited in a Part design. They can be edited in a Hybrid design.
Double-clicking on a CustomFeature in the timeline, does not open the feature for editing.
The contextual menu when a CustomFeature is right-clicked in the timeline also does not have the an "Edit Feature" menu item.
I believe the distinction between and Part design Hybrid design documents is relatively new concept in Fusion.
Perhaps with was overlooked. Is this a bug?
Message 84 of 84
xturgorex
This is some great insight. Thank you for figuring this out in terms of design workspaces. I've been trying to build a plugin using CustomFeature but I've been in a Part design. Confirmed that Custom Pocket does work in Hybrid.  You're right about the hybrid, assembly, part designs being new. Hybrid documents are the "old way" that fusion worked. The Part, Assembly, Hybrid change has broken the Custom Pocket Sample in Part design. This shift to new document styles in fusion has created quite a few headaches in terms of workflow.
