Creation of Plane at Angle
dozerdroid
dozerdroid
>> note I think I have found a solution see bottom ?
Hi, I am currently using code like below to create planes for sketches that are in the XY plane and offset on the Z axis, I have a points array which I use for the sketch in which all of the Z values are on the created XY plane
planesObj = hullComponent.constructionPlanes
planeInput = planesObj.createInput()
xyPlane = hullComponent.xYConstructionPlane
planeInput.setByOffset(xyPlane, offsetValue)
plane0 = planesObj.add(planeInput)
I now need to perform a similar task except the planes offset along the Z axis will be tilted as per below
I have not been successful so far in the API doing this so if someone can point me to an example or other help it would be appreciated. I can obviously create the plane manually by creating a plane through three points (all of the points in the array to draw line in the tilted plane) but I need to perform this in the api.
Thanks in advance. Khim
Ok I think I have found an answer below ?
planeInput.setByThreePoints
kandennti
Hi @dozerdroid .
Indeed, a three-point passing plane might be a good idea.
I made a sample of creating a plane of three points of passage while creating the points of the sketch.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import math
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        angle = 30 #degrees
        offsetZ = 1 # Z direction offset value
        offsetCount = 10
        # Calculate transit points
        rad = math.radians(angle)
        pnts = [
            core.Point3D.create(0,0,0),
            core.Point3D.create(1, math.cos(rad), math.sin(rad)),
            core.Point3D.create(-1, math.cos(rad), math.sin(rad)),
        # Sketch creation for reference
        skt: fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        skt.name = 'Plane Reference'
        skt.isLightBulbOn = False
        sketchPnts: fusion.SketchPoints = skt.sketchPoints
        # Vector for updating transit points
        vec: core.Vector3D = core.Vector3D.create(0, 0, offsetZ)
        for _ in range(offsetCount):
            # reference point creation
            sktPnts = [sketchPnts.add(p) for p in pnts]
            # create plane
            constPlanes: fusion.ConstructionPlanes = root.constructionPlanes
            planeIpt: fusion.ConstructionPlaneInput = constPlanes.createInput()
            planeIpt.setByThreePoints(
                sktPnts[0],
                sktPnts[1],
                sktPnts[2],
            constPlanes.add(planeIpt)
            # Updated transit points
            [p.translateBy(vec) for p in pnts]
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
dozerdroid
Thank you kandennti
