Create Sketch with Point and Vector
I would like to create a new sketch at a point (Point3D) facing along a Vector (Vector3D).
What would be my options to accomplish this?
I am guessing I can't get around creating a construction plane for the sketch to sit on.
I know I could generate a BRep face there but I would like to avoid that.
kandennti
Hi edidos
try this
#Fusion360API python
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        #Vector & Point
        vec = adsk.core.Vector3D.create(0,0,1)
        pnt = adsk.core.Point3D.create(2.0,3.0,4.0)
        #Doc
        app = adsk.core.Application.get()
        ui = app.userInterface
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des = app.activeProduct
        root = des.rootComponent
        planes = root.constructionPlanes
        planeInput = planes.createInput()
        #Plane
        pln3d = adsk.core.Plane.create(pnt, vec)
        planeInput.setByPlane(pln3d)
        des.designType = adsk.fusion.DesignTypes.DirectDesignType
        pln = planes.add(planeInput)
        des.designType = adsk.fusion.DesignTypes.ParametricDesignType
        #sketch
        skts = root.sketches
        skt = skts.add(pln)
        ui.messageBox('Done\n{}'.format(skt.name))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thank you.
This is exactly what I needed.
