Create arbitrary plane for sketch in a script
When writing scripts for the fusion 360 API one could use `sk = root.sketches.add(root.xYConstructionPlane)` to create a sketch plane to add points to. But is it possible to create a arbitrary plane given a normal or base vectors from global coordinates?
MichaelT_123
Yes Mr.Erikvk,
--> goto <API Documentation>
Sincerely
MichaelT
MichaelT
kandennti
Hi Erikvk.
After executing the script, click the face to create a tangent plane.
It continues until the ESC key is pressed.
#Fusion360API Python Script
#Author-kantoku
#Description-CreatePlane ClickPoint
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        planes = root.constructionPlanes
        msg = 'Click on the face / End is ESC key'
        skt = None
        while True:
            sel = SelectEnt(ui, msg, 'Faces')
            if sel is None:
                break
            if skt is None:
                skt = root.sketches.add(root.xYConstructionPlane)
            pnt = skt.sketchPoints.add(sel.point)
            InitPlane(planes, sel.entity, pnt)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def InitPlane(
        plns :adsk.fusion.ConstructionPlanes,
        surf :adsk.fusion.BRepFace,
        pnt :adsk.core.Point3D):
    plnInput = plns.createInput()
    if plnInput.setByTangentAtPoint(surf, pnt):
        plns.add(plnInput)
def SelectEnt(
        ui :adsk.core.UserInterface,
        msg :str,
        filtter_str :str) -> adsk.core.Selection :
    try:
        selection = ui.selectEntity(msg, filtter_str)
        return selection
    except:
        return None
enjoy!
