ConstructionPlaneInput usage example
class ConstructionPlaneInput(Base):
    """A ConstructionPlaneInput is a throwaway object used to create a ConstructionPlane
The usage pattern is:
a. create a ConstructionPlaneInput (ConstructionPlanes.CreateInput)
b. call one of the member functions to specify how the ConstructionPlane is created
c. create the ConstructionPlane (call ConstructionPlanes.Add)
d. stop referencing the ConstructionPlaneInput (so it gets deleted)."""
I found this in the fusion.py, i tryed than following
 consPlaneInput = adsk.fusion.ConstructionPlanes.createInput
 consPlaneInput.setByOffset(xyPlane,adsk.core.ValueInput.createByReal(10))
which fails telling me consPlaneInput has no member setByOffset, but that method is defined in funsion.py line 5790
any idea what could be going on .
One more question, is there a way to get propper debug output, that is not cut by the Window that it is in and that is maybe selectable and pasteable.
frankzhang
Hello, regarding the usage, we recommand that you take a look at the "Fusion 360 API Reference Manual" which can be accedded from this link:
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A
Specifically for ConstructionPlaneInput, look at this:
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-93edada4-bd64-4af5-977a-99f2f1ccd930
Here is also a sample that you can reference:
Construction Plane API Sample
