Constrain a line to a circle
billbedford
billbedford
I'm looking for the form of an entity that can be used to give a coincident constraint between a line end-point and a circle.
Thanks in advance
BrianEkins
The code below creates a circle, a line, and a coincident constraint between them.
import adsk.core, adsk.fusion, traceback
def run(context):
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        sk = root.sketches.add(root.xYConstructionPlane)
        circle = sk.sketchCurves.sketchCircles.addByCenterRadius(
                                adsk.core.Point3D.create(0,0,0), 5)
        line = sk.sketchCurves.sketchLines.addByTwoPoints(
                                adsk.core.Point3D.create(5,0,0),
                                adsk.core.Point3D.create(8,3,0))
        sk.geometricConstraints.addCoincident(line.startSketchPoint, circle)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
