Compare and Edit after running script
dames123
Message 1 of 25
dames123
I have a script I run that creates NCPrograms. It's crude as I'm not a coder. There's one line that creates an error when using Compare and Edit after creating the NCPrograms. It does something to the flag to set the machine to 1.
prg.machine = setup.machine  # Set the machine to the same as the setup
I get the following error message in Compare and edit.
Is this a bug in Fusion or is there another way to write that line in the script?
#n360API Python script
import adsk.core, adsk.fusion, adsk.cam, traceback
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.cam = app.activeProduct
        # https://url.us.m.mimecastprotect.com/s/R9VIC2kr1Nf6PQk3I9ku4o?domain=help.autodesk.com
        ncPrograms: cam.NCPrograms = camObj.ncPrograms
        for setup in camObj.setups:
            machineName = ""
            if setup.machine:
                # Access the name of the machine
                machineName = setup.machine.getName() if hasattr(setup.machine, 'getName') else "Unnamed Machine"
            # Log or display the machine name
            ui.messageBox(f"Setup: {setup.name}\nMachine: {machineName}")
            ncIpt: cam.NCProgramInput = ncPrograms.createInput()
            ncIpt.displayName = setup.name
            ncParameters = ncIpt.parameters
            ncParameters.itemByName('nc_program_filename').value.value = setup.name
            ncParameters.itemByName('nc_program_openInEditor').value.value = False
            ncParameters.itemByName('nc_program_useMachineConfig').value.value = True
            ncParameters.itemByName('nc_program_filename').value.value = setup.parameters.itemByName('job_programName').value.value # Set the filename to the same as the setup
            ncParameters.itemByName('nc_program_comment').value.value = setup.parameters.itemByName('job_programComment').value.value
            ncIpt.operations = [setup]
            prg = ncPrograms.add(ncIpt)
            # Duplicate the NCProgram
            duplicatedPrg = prg.duplicate()
            if duplicatedPrg:
                camObj.ncPrograms[-1].name = (setup.name + " SETUPSHEET")
                #ncParameters = duplicatedPrg.parameters
                # Set the post processor path only for the duplicated program
                post_processor_path = 'linked://' + 'setup-sheet-excel-2007.cps'
                ncParameters.itemByName('nc_program_post').value.value = post_processor_path
            else:
             ui.messageBox(f"Failed to duplicate NCProgram for setup: {setup.name}")
        ui.messageBox("Dont forget to set your tool numbers")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Any help is appreciated.
Accepted solutions (3)
Replies (24)
Message 21 of 25
nubrandao
I will try thanks very much
Message 22 of 25
nubrandao
Failed:
Traceback (most recent call last):
File "C:/Users/bnuno/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/NewScript1/NewScript1.py", line 54, in run
File "C:\Users/bnuno/AppData/Local/Autodesk/webdeploy/pre-production/8f3280571a21b8ce3de79e366dcfbc59dbd1237e/Api/Python/packages\adsk\cam.py", line 15786, in _set_value
return _cam.ChoiceParameterValue__set_value(self, value)
RuntimeError: 1 : Catastrophic error occurred in API function call
gives this error, what i have to change?
Message 23 of 25
Jorge_Jaramillo
It seems that your are not using the last version I sent, because that sentence where you get the error is not in that latest version.
If you're using other version, it is very handy that you share your routine/function so we can analyze it and provide a feedback. Just the error message is not enough (I believe)
Jorge Jaramillo
Message 24 of 25
nubrandao
tried the last version, it crashed fusion, hmm going to remove machine from setup, going to try
Message 25 of 25
nubrandao
It works now, I have to change to my current post Heidenhain
Perfect
