Commands for Pipe with code
rocco.mayr
rocco.mayr
In this post I found how a pipe could be created with code:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands/m-p/9645688
There are some commands shown in the script:
def initPipe(path):
    sels :adsk.core.Selections = _ui.activeSelections
    sels.clear()
    sels.add(path)
    txtCmds = [
        u'Commands.Start PrimitivePipe', # show dialog
        u'Commands.SetDouble SWEEP_POP_ALONG 1.0', # input distance
        u'Commands.SetDouble SectionRadius 0.5', # input radius
        u'NuCommands.CommitCmd' # execute command
    for cmd in txtCmds:
        _app.executeTextCommand(cmd)
    sels.clear()
Where could I find the other commands for setting up the pipe - like "Commands.SetDouble SectionRadius 0.5"?
rocco.mayr
Now I found it out. You will find the commands if you open Fusion 360. On the bottom open the menu "TEXT COMMANDS". Then click on Solid -> Create -> Pipe. Click on the pipe menu and then enter on the "TEXT COMMANDS" menu the command:
"Toolkit.cmdDialog"
Here is the output from today:
====>  CommandDialog:PrimitivePipePanel-0
Path, eSelectionButton, Label=Path, 1 selected
SWEEP_CHAINING_OPTION, eCheckBox, Chain Selection
SWEEP_POP_ALONG, eDropDownEntry, Distance, 1.00
  MenuItems:
  MRUValueCommand, eDropDownItem, 1.00
  MRUValueCommand, eDropDownItem, 0.034
  MRUValueCommand, eDropDownItem, 2.40
  MRUValueCommand, eDropDownItem, 0.40
  MRUValueCommand, eDropDownItem, 0.00
SWEEP_POP_AGAINST, eDropDownEntry, Distance, 0.00
  MenuItems:
infoSectionType, eDropDownButton, Label=Section, Circular
  MenuItems:
  infoCircular, eDropDownItem, Circular
  infoRectangular, eDropDownItem, Square
  infoTriangular, eDropDownItem, Triangular
SectionRadius, eDropDownEntry, Section Size, 11.338 mm
  MenuItems:
  MRUValueCommand, eDropDownItem, 24.00 mm
  MRUValueCommand, eDropDownItem, 24 mm
  MRUValueCommand, eDropDownItem, 5.00 mm
  MRUValueCommand, eDropDownItem, 2.125 mm
  MRUValueCommand, eDropDownItem, 1.125 mm
  MeasureCommand, eDropDownItem, Measure
  Reanchor, eDropDownItem, Re-anchor
SectionThickness, eDropDownEntry, Section Thickness, 2.835 mm
  MenuItems:
  MRUValueCommand, eDropDownItem, 4.00 mm
  MRUValueCommand, eDropDownItem, 6.00 mm
  MRUValueCommand, eDropDownItem, 1.25 mm
  MRUValueCommand, eDropDownItem, 0.531 mm
  MRUValueCommand, eDropDownItem, 0.281 mm
PIPE_HOLLOW_OPTION, eCheckBox, Hollow
infoBooleanType, eDropDownButton, Label=Operation, New Body
  MenuItems:
  infoJoinType, eDropDownItem, Join
  infoCutType, eDropDownItem, Cut
  infoIntersectType, eDropDownItem, Intersect
  infoNewBodyType, eDropDownItem, New Body
  infoNewBodyInNewCompType, eDropDownItem, New Component
kandennti
Hi @rocco.mayr .
There's more to it.
I couldn't find it for a long time, but I found a way to change the "eDropDownButton" and described it here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands2/m-p/10267986#M13156
I'll let you know in advance.
The TextCommands specification is deprecated by Autodesk.
There is very little information available, and if it is wrong, it will often crash.
It is very difficult to develop and the processing speed is slow.
If you don't have any problems with it, I recommend you to use Sweep.
rocco.mayr
Yes you're right with the other commands it even works for the SectionType. But with the Hollow option I still struggle:
infoBooleanType = 'infoNewBodyType'
u'Commands.SetString infoBooleanType {}'.format(infoBooleanType)
#PIPE_HOLLOW_OPTION
With this command the pipe doesn't get hollow.
So I tried different Commands:
u'Commands.SetBool infoBooleanType {}'.format('true')
u'Commands.SetString infoBooleanType {}'.format('true')
u'Commands.SetBool PIPE_HOLLOW_OPTION {}'.format(infoBooleanType)
u'Commands.SetString PIPE_HOLLOW_OPTION {}'.format(infoBooleanType)
But no success, not getting hollow. Using 'PIPE_HOLLOW_OPTION' gives an error. Do you have an idea?
kandennti
@rocco.mayr .
I checked it out.
# check ON
Commands.SetBool PIPE_HOLLOW_OPTION 1
# check OFF
Commands.SetBool PIPE_HOLLOW_OPTION 0
I am trying the text command with the dialogs displayed, because running it in a script is a lot of work.
