commandInputs and childCommandInputs (TableCommandInput API Documentation)
nnikbin
nnikbin
In the following 4 pages of the API Documentation (including an API sample) a property named "childCommandInputs" is used. It seems that the correct property name should be "commandInputs" instead of childCommandInputs.
TableCommandInput.addCommandInput Method
TableCommandInput.addToolbarCommandInput Method
TableCommandInput Object
Command Inputs API Sample
Navid
liujac
You are correct. It's a documentation issue. The property should be commandInputs. Thanks for reporting this issue.
Jack
