Combine solid bodies C++
galaxyblazer
galaxyblazer
Hi.
Can somebody provide me a sample code which combine solid bodies in Fusion 360?
liujac
I wrote the C++ sample as below. Make sure there are at least two bodies under the root component before you run the script.
#include <Core/Application/Application.h>
#include <Core/Application/ObjectCollection.h>
#include <Fusion/Fusion/Design.h>
#include <Fusion/Components/Component.h>
#include <Fusion/BRep/BRepBodies.h>
#include <Fusion/BRep/BRepBody.h>
#include <Fusion/Features/Features.h>
#include <Fusion/Features/CombineFeatures.h>
#include <Fusion/Features/CombineFeatureInput.h>
using namespace adsk::core;
using namespace adsk::fusion;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
	Ptr<Application> app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
	Ptr<Design> design = app->activeProduct();
	if (!design)
		return false;
	// Get the root component of the active design
	Ptr<Component> root = design->rootComponent();
	if (!root)
		return false;
	Ptr<BRepBodies> bodies = root->bRepBodies();
	if (!bodies)
		return false;
	Ptr<BRepBody> targetBody = bodies->item(0);
	if (!targetBody)
		return false;
	Ptr<BRepBody> toolBody = bodies->item(1);
	if (!toolBody)
		return false;
	Ptr<ObjectCollection> toolBodies = ObjectCollection::create();
	if (!toolBodies)
		return false;
	toolBodies->add(toolBody);
	Ptr<Features> feats = root->features();
	if (!feats)
		return false;
	Ptr<CombineFeatures> combines = feats->combineFeatures();
	if (!combines)
		return false;
	Ptr<CombineFeatureInput> combineInput = combines->createInput(targetBody, toolBodies);
	if (!combineInput)
		return false;
	Ptr<CombineFeature> combine = combines->add(combineInput);
	return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
	switch (reason)
	case DLL_PROCESS_ATTACH:
	case DLL_THREAD_ATTACH:
	case DLL_THREAD_DETACH:
	case DLL_PROCESS_DETACH:
		break;
	return TRUE;
#endif // XI_WIN
Jack
galaxyblazer
Does Fusion API provides feature to get all selected bodies and then make some operations with that objects (Something like SelectionSet in AutoCad .net api)? I mean, that I want combine more than two objects in one function.
liujac
Yes, it's able to get all selections through UserInterface.activeSelections. For example:
	if (!app)
		return false;
	if (!ui)
		return false;
	Ptr<Selections> sels = ui->activeSelections();
	if (!sels)
		return false;
	for (Ptr<Selection> sel : sels)
		Ptr<BRepBody> body = sel->entity();
		if (body)
Jack
