Combine Feature not returned
j.han97
j.han97
Hi all,
I have noticed something weird (to me) with the API. While using Combine feature to cut bodies, there is nothing returned. I.e.,
combineFeature = combineFeatures.add(combineFeatureInput)
The combineFeature is null in this case.
I went to read the documentations, and it explicitly stated that "This function returns nothing in the case where the feature is non-parametric". What is the reason of this behavior? I have used some other Features as well (PatchFeatures, etc) and there is no such issue.
I actually expected to obtain the bodies after the cut, and if combineFeature was not returned, how should I determine which bodies are resulted from this operation?
BrianEkins
Notice that when you create a Combine feature when Fusion is in direct modeling mode that there isn't a combine feature shown in the browser. As a result, there's nothing to return.  Even in cases when there is a feature in the browser, they're "fake" features in that they don't remember all of the information that was used to create it. Instead, they act as a way of grouping the faces that were created by that feature.
In your case, I think you can probably get what you need by getting the bodies before and after and can assume all the new bodies were created by the Combine feature.
Brian Ekins
j.han97
Hi @BrianEkins ,
Thanks for your advice. Considering the potential number of bodies, I was worried about the impact on performance if I compare the bodies before and after. Currently I just switch to parametric modelling temporarily and perform the cut action, collect the resulting bodies in a list and switch back to direct modelling.
I noticed that switching the modelling environment did produce some lag as well, so I will compare these two methods before actual decision.
Alternatively, if NewComponentFeatureOperation is selected for CombineFeatureInput, is it possible to specify/obtain the new component created? This way the resulting bodies have to be in the new component, which makes it easier to get them.
BrianEkins
I think you should be able to count on getting the last occurrence in the occurrences collection and then getting the component from it. I would use the Occurrences.asArray method since that is guaranteed to return the occurrences in the same order as they appear in the browser. I didn't test it, so hopefully that all works when in direct modeling mode.
Brian Ekins
j.han97
Thanks @BrianEkins , this might be the easiest approach under such conditions. I have done a simple test (under static list) and it worked well. Might need to further test it during dynamic changes (add/remove occurrences, etc).
