Changing the CameraType
kandennti
Mentor Mentor
kandennti
Hey there everyone.
I am thinking of changing the Camera.cameraType Property in an add-in.
I have created the following script for my next test.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
_CAMERA_TYPES = [
    'OrthographicCameraType',
    'PerspectiveCameraType',
    'PerspectiveWithOrthoFacesCameraType'
_CAMERA_TYPES_LIST = [
    adsk.core.CameraTypes.OrthographicCameraType,
    adsk.core.CameraTypes.PerspectiveCameraType,
    adsk.core.CameraTypes.PerspectiveWithOrthoFacesCameraType,
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        vp: adsk.core.Viewport = app.activeViewport
        cam: adsk.core.Camera = vp.camera
        backupCameraType = cam.cameraType
        backupOriginFolderLight = root.isOriginFolderLightBulbOn
        root.isOriginFolderLightBulbOn = True
        for ct in _CAMERA_TYPES_LIST:
            cam.cameraType = ct
            cameraUpdate(vp, cam)
            cam = vp.camera
            ui.messageBox(_CAMERA_TYPES[cam.cameraType])
        cam.cameraType = backupCameraType
        root.isOriginFolderLightBulbOn = backupOriginFolderLight
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def cameraUpdate(
        vp: adsk.core.Viewport,
        cam: adsk.core.Camera):
    vp.camera = cam
    vp.refresh()
    vp.fit()
Here is the result.
"adsk.core.CameraTypes.PerspectiveWithOrthoFacesCameraType" is very different from the one I set in the GUI.
Is this the correct display?
I am using Fusion360 Ver2.0.10940.
BrianEkins
I can reproduce the problem and it does appear to be a bug and has been logged.
Brian Ekins
kandennti
Thanks @BrianEkins .
I will not use "adsk.core.CameraTypes.PerspectiveWithOrthoFacesCameraType" in the add-in.
