Changing feeds and speeds requires regenerating toolpath for drill operations
avandertoorn
avandertoorn
When updating feeds and speeds through the API for drill operations, it places the drill operation in a "Toolpath out of date" state, necessitating regeneration. This does not happen for any of the milling operations that I've encountered, which leads me to believe that the same should be expected for drilling. Of course, regenerating the toolpath is a straightforward solution. However, a larger issue arises when, for instance, an adaptive toolpath uses rest machining, as it also places all these toolpaths into a "Toolpath out of date" state. I do not wish to regenerate all toolpaths that get put into an invalid state every time as I don't want to potentially change a toolpath and add a lot of extra time.
Is this something that should be fixed?
jeff.pek
Can you share a sample script that demonstrates this?
Thanks!
  Jeff
kandennti
Hi @avandertoorn .
I tried to confirm it with "Face" and "Drill". It can be reproduced.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = app.activeProduct
        setup: cam.Setup = camObj.setups[0]
        print(f"ver {app.version}")
        change_feed(setup.operations[0])
        change_feed(setup.operations[1])
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def change_feed(
    ope: cam.Operation,
) -> None:
    if ope.strategy == "drill":
        prmName = "tool_feedPlunge"
    else:
        prmName = "tool_feedCutting"
    prm: cam.ParameterValue = ope.parameters.itemByName(
        prmName
    msgLst = [
        f"** Name: {ope.name} **",
        f"Before Feed: {prm.value.value}",
        f"Before State: {ope.operationState}",
    prm.value.value += 100
    msgLst.extend(
            f"After Feed: {prm.value.value}",
            f"After State: {ope.operationState}",
    print("\n".join(msgLst))
ver 2.0.16761
** Name: Face1 **
Before Feed: 1000.0
Before State: 0
After Feed: 1100.0
After State: 0
** Name: Drill1 **
Before Feed: 1000.0
Before State: 0
After Feed: 1100.0
After State: 1
avandertoorn
@kandennti,
Thanks for taking the time to test this out on your end.
I added a few toolpaths with 'Rest Machining' on with 2 of them and off with the last one.
import traceback
def run(context):
    try:
        print("\n\nBefore Change")
        print("------------------")
        print_state(setup.operations[2])
        print_state(setup.operations[3])
        print_state(setup.operations[4])
        print("\n\n")
        print("\n\nAfter Change")
    except:
        if ui:
def change_feed(
    ope: cam.Operation,
) -> None:
    else:
        prmName
    msgLst = [
    msgLst.extend(
def print_state(
    ope: cam.Operation,
) -> None:
    msgLst = [
        f"State: {ope.operationState}",
        f"Rest: {cam.BooleanParameterValue.cast(ope.parameters.itemByName('useRestMachining').value).value}"
ver 2.0.16976
Before Change
** Name: Adaptive1 **
State: 0
Rest: True
** Name: Pocket1 **
State: 0
Rest: True
** Name: Pocket1 (2) **
State: 0
Rest: False
** Name: Face1 **
Before Feed: 1000.0
Before State: 0
After Feed: 1100.0
After State: 0
** Name: Drill1 **
Before Feed: 1000.0
Before State: 0
After Feed: 1100.0
After State: 1
After Change
State: 1
Rest: True
** Name: Pocket1 **
State: 1
Rest: True
State: 0
Rest: False
Also, I noticed the same thing happens when updating feeds and speeds through the UI except for the edited operation is obviously regenerated when clicking "OK".
avandertoorn
What is the process for getting issues like this looked at by the development team?
