Change workspace
Change workspace
dinocoglitore
Change workspace
dinocoglitore
Hi all,
I'm looking for APIs that help me to change the workspace from Model to Render.
I found in the forum an example to view all the Environments and I add two line to change the workspace (in my mind...) but nothing append.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        print("\n\n")
        for workspace in ui.workspaces:
            print(workspace.id)
        ui.workspaces.id = "FusionRenderEnvironment"
        ui.workspaces.itemById = "FusionRenderEnvironment"
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Someone can help me ?
Thank you
Dino
ekinsb
The Workspaces object provides access to all of the existing workspaces.  The item and itemById methods provide a way to access the contents of the collection but they are functions that return a value and can't be used to set the workspace.  You do that on the Workspace object.  The code below will do it.
renderWS = ui.workspaces.itemById("FusionRenderEnvironment")
renderWS.activate()
Brian Ekins
Mod the Machine blog
dinocoglitore
Hi Brian.
Thank you very much.
Dino
I want to create add-in python script which aims at exporting mesh of my geometry in VTK format. For this, my script needs to open the simulation environment workspace (script add-ins are runnable only in FusionSolidEnvironment workspace)
I wrote the following code
import adsk.core, adsk.fusion, tempfile, traceback
def run(context):
    ui = None
    try:
        design = app.activeProduct
        # Get the ExportManager from the active design.
        exportMgr = design.exportManager
        tmpDir = tempfile.gettempdir()
        # Create an STEPExportOptions object and do the export.
        stepOptions = exportMgr.createSTEPExportOptions('C:/Users/rrochefort/Documents/Python_Scripts/test.stp')
        res = exportMgr.execute(stepOptions)
        # Create vtu
        renderWS = ui.workspaces.itemById("SimulationEnvironment")
		renderWS.activate()
        app.executeTextCommand(u'SimMeshDB.Export  0  C:/Users/rrochefort/Documents/Python_Scripts/my_mesh.vtu')
When I run this script, nothing happens, and I get no error message
I think the problem is that scripts are only runnable in FusionSolidEnvironment workspace.
Could you help me please on this problem ? How can I automate the exporting of my mesh ?
