Change 'Model Parameter' problem
brad.bylls
brad.bylls
I am changing the values in the model parameters to be inches not metric.
The code below works for "setDistanceExtent" but not for "setSymmetricExtent"
I have been playing with the code but can't seem to figure it out.
    # Change to inches in Parameters
    extent_2 = adsk.fusion.DistanceExtentDefinition.cast(dowelODExt.extentOne)
    distanceMP_2 = adsk.fusion.ModelParameter.cast(extent_2.distance)   <<<<<<<< Line 191
    distanceMP_2.expression = "{:.{}f}".format(((numDowelLength * -1) / sizeUnits), 4) + 'in'
    dowelODExt.name = 'Dowel Length'
This is the error message I get:
Brad Bylls
kandennti
Hi @brad.bylls .
The extentOne property for symmetry is now a SymmetricExtentDefinition object instead of a DistanceExtentDefinition object.
The easiest way to deal with this would be to stop the casting.
        # extent_2 = adsk.fusion.DistanceExtentDefinition.cast(dowelODExt.extentOne)
        extent_2  = dowelODExt.extentOne
        distanceMP_2 = adsk.fusion.ModelParameter.cast(extent_2.distance)   #<<<<<<<< Line 191
brad.bylls
What is casting?
And then what?
I took the original code from a sample script.
Brad Bylls
kandennti
@brad.bylls .
There may be a better site, see here.
https://www.programiz.com/python-programming/type-conversion-and-casting
In this case, type conversion is not possible, so None will be assigned as it is.
You can avoid the error by using this method.
brad.bylls
Thanks Kandennti.
It worked great once I shut down F360 and restarted it.
Brad Bylls
