Change in the behavior of BRepBody.deleteMe() method
nnikbin
nnikbin
Today, after installing February 1, 2017 Update of Fusion 360, I found that one of my add-ins is broken. Debugging the add-in revealed a change in the behavior of deleteMe() method. I do not know whether February 1 update has caused it or some previous updates (perhaps January 26 update).
I summarized the old and new behaviors here:
Old behavior:
  • Invoking deleteMe() on an occurrence --> deletes the occurrence
  • Invoking deleteMe() on a BRepBody which is the result of a feature (Like SplitBodyFeature or ExtrudeFeature) --> inserts a Remove feature in the timeline
New behavior:
  • Invoking deleteMe() on an occurrence --> deletes the occurrence (no change in the behavior)
  • Invoking deleteMe() on a BRepBody which is the result of a feature (Like SplitBodyFeature or ExtrudeFeature) --> deletes the feature (change in the behavior)
Suppose you split a sphere from the middle using SplitBodyFeature, then you invoke the deleteMe() on one of the split parts. The new version results a sphere (it deletes the split feature) while the old version results a hemisphere (it removes one split part).
I think it may cause some add-ins to function incorrectly, so they will need updates
Navid
marshaltu
The behavior change of the API was intended. We found the old behavior of the API was different from the one in UI and made the correction.
Ideally any API behaviors should follow the ones in UI, which can give better expectation to API clients when they use APIs.
Unfortunately the addins which depended on the old behavior have to be updated accordingly. Sorry for the confusion. We will try our best to avoid such case in the future.
Marshal
Marshal Tu
Fusion Developer
nnikbin
Hello @marshaltu,
Thanks for your answer. I totally agree with you that the new behavior is more consistent with UI (and also with the behavior of this method in other parts of the API)
Navid
