Catastrophic error occurred in API function call
karolis.s
karolis.s
Hello, I am playing with the new capabilities of Fusion 360 CAM API.
I don't understand why I get this error message, I looked at examples of how to retrieve this parameter at least several times. I can't see what I did wrong here.
Error message:
Here is a proof I have valid template file:
Source code:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback, os
camOptemplateSource = 'C:\\Users\\kkriv\\AppData\\Roaming\\Autodesk\\CAM360\\templates\\'
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cam: adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
        camOcc = cam.designRootOccurrence
        body = camOcc.bRepBodies[0]
        cam: adsk.cam.CAM = cam
        setups = cam.setups
        # Create a SetupsInput object to define a milling setup.
        setupInput = setups.createInput(adsk.cam.OperationTypes.MillingOperation)
        setupInput.models = [body]
        setupInput.name = 'DEBUG'
        setup = setups.add(setupInput)
        orientationParam = setup.parameters.itemByName('wcs_orientation_mode')
        choiceVal: adsk.cam.ChoiceParameterValue = orientationParam.value
        choiceVal.value = 'axesZX'
        originPoint = setup.parameters.itemByName('wcs_origin_boxPoint')
        choiceVal: adsk.cam.ChoiceParameterValue = originPoint.value
        choiceVal.value = 'center'
        template = getTemplate()
        results = setup.createFromTemplate(template)
        op: adsk.cam.Operation = results.item(0)
        contourParam: adsk.cam.CadContours2dParameterValue = op.parameters.itemByName('contours').value
        curveSelections = contourParam.getCurveSelections()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getTemplate():
        source = camOptemplateSource + 'Contours'
        templates = os.listdir(source)
        return source + '\\' + templates[0]
karolis.s
If I try to use an alternative I get 'Unknown strategy' error.
kandennti
Hi @karolis.s .
I don't know the cause, but I tried it on a whim and was able to avoid the error.
        op.isSuppressed = True
        op.isSuppressed = False
