Capture background commands on Icon click
MrABlackwell
MrABlackwell
How can I display the command line in real time when an icon is selected.
If I can see what's happening when I click an Icon, it would help to build a script.
kandennti
Hi @MrABlackwell .
I didn't know which icon you meant, but when some command is executed, it is possible to know what command was called.
The UserInterface.commandStarting event is an event that is fired when a command is invoked.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-EBB6C82A-A256-4AB7-9A86-0F7A9653A7E9
I have published an add-in that uses this event to display the invoked command information log in a text command window.
https://github.com/kantoku-code/Fusion360_Developers_Small_ToolKit
By setting this switch to On, the log display starts.
Please forgive that the description is only in Japanese, as I created this add-in for my personal use.
