Cannot load addin if in UI Preview mode
Le_Bear
Le_Bear
I believe this is a known problem, but I would like to know if there is new APIs methods to detect if the new UI has been activated, and maybe not even load the addin if yes, as a temporary solution.
The obvious next step would be to load the addin in the new UI, with the proper method for the new UI.
Any idea when documentation about this would be available?
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
BrianEkins
When the new UI was first available no add-ins were being shown.  Autodesk has done some work to map the old UI to the new so when you add your add-in into the old UI it will automatically add it into a corresponding location into the new UI.  I'm sure there are limitations to this.  There hasn't been any new API provided yet to work with the new UI.
Brian Ekins
Le_Bear
Thank you Brian. I will test and accept your solution as soon as I see it's working. Even better if there is no changes in the API, hence nothing to do.... 🙂
Bernard Grosperrin
Le_Bear
Nope, does not work!
Bernard Grosperrin
