Cannot delete timeline group from add-in: InternalValidationError
kriomant
kriomant
I have add-in with command which does this:
    design = adsk.fusion.Design.cast(app.activeProduct)
    timeline = design.timeline
    for selection in ui.activeSelections:
        selectedEnt = selection.entity
        timelineObj = selectedEnt.timelineObject
        timelineObj.parentGroup.deleteMe(False)
Various checks are removed for brevity. Only one entity is selected, it's inside of timeline group, but I get
File "…/adsk/fusion.py", line 95662, in deleteMe
return _fusion.TimelineGroup_deleteMe(self, deleteGroupAndContents)
RuntimeError: 2 : InternalValidationError : res
BrianEkins
I tried to reproduce this by creating many sketches, grouping some, and then deleting the group using the API. It works OK for me. Maybe the type of objects in the group is causing the different behavior?
Brian Ekins
kriomant
Seems I nailed it: group must be collapsed for you to be able to delete it.
