Can the RGB colour of a BRepBody be set?
Message 1 of 9
Can the RGB colour of a BRepBody be set to a user specified value using the API (in C++).
I've been tracing through the API and it looks like the material (texture, colour, etc) can only be set
from the existing materials library. I would like to specify "plastic" (from the library) but give it my
own RGB values.
If it can be done, how? I can't find a create function for a Ptr<Appearance>.
Replies (8)
Message 2 of 9
MichaelT_123
dig around ... color = adsk.core.Color.create( int(_r), int(_g), int(_b), opacity) # create(red, green, blue, opacity)
MichaelT
Message 3 of 9
Yes, I found that, but how do you set a Ptr<PRebBody>  with a Ptr<Color>? I can't find any
modify functions for a Ptr<Apearence>, I can only find functions to copy them about, i.e
from the materials library. Once I set a Ptr<Appearence> with a Ptr<Color> I can set the
Ptr<PRepBody> with the Ptr<Appearance>
Message 4 of 9
BrianEkins
Hopefully, this will help.
https://ekinssolutions.com/setting-colors-in-fusion-360/
Brian Ekins
Message 5 of 9
MichaelT_123
(int(Excellence ** Magnificence))!
MichaelT
Message 6 of 9
Thanks Brian.
Message 7 of 9
MichaelT_123
Hi, Mr Ekinks
I think I have share ... it with you!!!
As you presented your wonderful response ...  giving your customer ... 'the fish' ...
I have looked at your code and mine I laboured some time ago ...
Let's have a look:
Your sample:
colorProp = adsk.core.ColorProperty.cast(prop)
val = colorProp.value
if val:
result += ' Value: ' + (str(val.red) + ',' +
str(val.green) + ',' +
str(val.blue) + ',' +
str(val.opacity) + '\n')
else:
result += ' Value: Undefined\n'
elif prop.objectType == adsk.core.StringProperty.classType():
strProp = adsk.core.StringProperty.cast(prop)
result += ' Value: ' + strProp.value + '\n'
elif prop.objectType == adsk.core.FloatProperty.classType():
floatProp = adsk.core.FloatProperty.cast(prop)
result += ' Value: ' + str(floatProp.value) + '\n'
elif prop.objectType == adsk.core.BooleanProperty.classType():
boolProp = adsk.core.BooleanProperty.cast(prop)
result += ' Value: ' + str(boolProp.value) + '\n'
elif prop.objectType == adsk.core.ChoiceProperty.classType():
choiceProp = adsk.core.ChoiceProperty.cast(prop)
result += ' Value: ' + str(choiceProp.value) + '\n'
(returnValue, names, choices) = choiceProp.getChoices()
Mine sample:
for a in range( _propAppear.count 😞
aP = _propAppear.item(a)
apName = aP.name
apROnly = aP.isReadOnly
if ( apROnly == True 😞
apROnly = '<R>'
else:
apROnly = ''
apName = apName + apROnly
apType = aP.objectType
if ( apType == adsk.core.ColorProperty.classType() 😞
apColor = aP.value
if ( apColor == None 😞
maValue = 'Texture'
else:
maValue = '[{:d},{:d},{:d},{:d}]'.format( apColor.red, apColor.green, apColor.blue, apColor.opacity )
elif( apType == adsk.core.StringProperty.classType() 😞
apValue = aP.value
elif( apType == adsk.core.IntegerProperty.classType() 😞
apValue = aP.value
elif( apType == adsk.core.FloatProperty.classType() 😞
apValue = aP.value
elif( apType == adsk.core.ChoiceProperty.classType() 😞
apValue = aP.value
elif( apType == adsk.core.BooleanProperty.classType() 😞
apValue = aP.value
else:
try:
apValue = aP.value
except:
apValue = None
if ( apValue != None 😞
#propRecord.append( apType )
propRecord.append( apName )
propRecord.append( apValue )
I was so amazed! ... and no I am not saying that we copied from each other ...
but we certainly have had  copied from somebody/something else Smiley Wink
Best Regards
MichaelT
MichaelT
Message 8 of 9
adminTCYL2
Hi Brian,
The link that is given by you for a solution of this posting does not work anymore:
... so the posting got no solution right now.
Message 9 of 9
BrianEkins
Thanks for letting me know about the problem on my website.  I'll work on getting it fixed but it may be a few days before I can get to it.
Brian Ekins
