CAM postProcess "Initialization fails"
lorraine5RWGT
lorraine5RWGT
Getting an "initialization fails" error when using `cam.postProcessAll` or `cam.postProcess`.  Can anyone shed some light why?  Post process works when clicking through UI.
        programName = '1001'
        postConfiguration = os.path.join(cam.genericPostFolder, 'mach3mill.cps')
        outputFolder = 'C:/Users/lorraine/AppData/Local/Fusion 360 CAM/nc'
        outputUnits = adsk.cam.PostOutputUnitOptions.MillimetersOutput
        postInput = adsk.cam.PostProcessInput.create(programName, postConfiguration, outputFolder, outputUnits)
        post_success = cam.postProcessAll(postProcessInput)  # Produces error
Failed:
Traceback (most recent call last):
    post_success = cam.postProcessAll(postInput)
  File "C:/Users/lorraine/AppData/Local/Autodesk/webdeploy/production/a93b41817d8af77c4f46fcf4f87b0f003298f7f0/Api/Python/packages\adsk\cam.py", line 375, in postProcessAll
    return _cam.CAM_postProcessAll(self, *args)
RuntimeError: 3 : Initialization fails.
boopathi.sivakumar
Are you trying to post process it through some scripts or API?
If so then its missing the cam.postProcess() requires two things one is inputs and other is the setup details you want to post
here is the sample api program
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-BF31EB56-B612-44C8-8F07-0C183036C803
Boopathi Sivakumar
Senior Technology Consultant
lorraine5RWGT
Hi,  thanks for the reply.
It happens both when I use cam_var.postProcessAll with 1 arg (postProcessInput) and when I use cam_var.postProcess with 2 args (operation, postProcessInput)
boopathi.sivakumar
@lorraine5RWGT
Could you attach the script?
Boopathi Sivakumar
