Calling document.dataFile raises error if document was just saved to datafile
lorraine5RWGT
lorraine5RWGT
    # Document creation options
    documentType = adsk.core.DocumentTypes.FusionDesignDocumentType # int 0
    visible = True  # Fusion currently only supports True
    options = None
    doc = app.documents.add(documentType, visible, options)
    description = ''
    tag = ''
    # Save version 1
    doc.saveAs(datafile_name, folder, description, tag)
    time.sleep(15)  # testing, arbitrary
    doc.activate()
    # Workaround to Fusion's 'Failed to download file' error
    time.sleep(6)
    print('doc.isSaved: ' + str(doc.isSaved))
    print('doc.isValid: ' + str(doc.isValid))
    print('doc.dataFile: ' + str(doc.dataFile))
Output:
doc.isSaved: True
doc.isValid: True
RUntimeError: 2 : InternalValidationError : dataFile
goyals
May be file is not uploaded to the cloud yet and you are trying to get dataFile early hence this problem is noticed though file is saved locally. Not sure what is the best way to know when file is actually uploaded to cloud. We do have DataFileFuture class defined which is used when file is uploaded directly using upload function on DataFolder so may be we should provide similar object in case of Save.
Shyam Goyal
Sr. Software Dev. Manager
