C++ assembly recursion sample
Message 1 of 1
Not exactly a question, but more of an information(?)
The code on the C++ version of this (https://help.autodesk.com/view/fusion360/ENU/?guid=AssemblyTraversalUsingRecursion_Sample) is wrong. It opens a new assemble, runs the recursion, adds a couple of components and exits without outputting anything.
Perhaps an honest mistake, but rather infuriating for someone that never compiled C++ things under windows with Visual Studio, as it took me some time to figure out what was wrong. The code should be:
#include <Core/Application/Application.h>
#include <Core/Application/Documents.h>
#include <Core/Application/Document.h>
#include <Core/Application/Product.h>
#include <Core/Geometry/Matrix3D.h>
#include <Core/UserInterface/UserInterface.h>
#include <Fusion/Components/Component.h>
#include <Fusion/Components/Occurrence.h>
#include <Fusion/Components/Occurrences.h>
#include <Fusion/Components/OccurrenceList.h>
#include <Fusion/Fusion/Design.h>
using namespace adsk::core;
using namespace adsk::fusion;
Ptr<UserInterface> ui;
// Returns a string containing the especified number of spaces.
std::string spaces(size_t spaceCount) {
	std::string result = "";
	for (size_t i = 0; i < spaceCount; ++i) {
		result += " ";
	return result;
// Performs a recursive traversal of an entire assembly structure.
std::string traverseAssembly(Ptr<OccurrenceList> occurrences, size_t currentLevel, std::string inputString) {
	if (occurrences) {
		for (size_t i = 0; i < occurrences->count(); ++i) {
			Ptr<Occurrence> occ = occurrences->item(i);
			if (occ) {
				inputString += spaces(currentLevel * 5) + "Name: " + occ->name() + "\n";
				if (occ->childOccurrences()) {
					inputString = traverseAssembly(occ->childOccurrences(), currentLevel + 1, inputString);
	return inputString;
extern "C" XI_EXPORT bool run(const char* context)
	Ptr<Application> app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
//REMoved: //Ptr<Documents> documents = app->documents(); //if (!documents) // return false; //Ptr<Document> doc = documents->add(DocumentTypes::FusionDesignDocumentType); //if (!doc) // return false; Ptr<Product> product = app->activeProduct(); if (!product) return false; Ptr<Design> design = product; if (!design) return false; // Get the root component of the active design Ptr<Component> rootComp = design->rootComponent(); if (!rootComp) return false; Ptr<Occurrences> occurrences = rootComp->occurrences(); if (!occurrences) return false;
//REmoved: //occurrences->addNewComponent(Matrix3D::create()); //occurrences->addNewComponent(Matrix3D::create()); // Create the title for the output. std::string resultString = "Assembly structure of " + design->parentDocument()->name() + "\n"; // Call the recursive function to traverse the assembly and build the output string. resultString = traverseAssembly(occurrences->asList(), 1, resultString); //Added: we want to see what the resultString is, don't we???
ui->messageBox(resultString); return true; } #ifdef XI_WIN #include <windows.h> BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved) { switch (reason) { case DLL_PROCESS_ATTACH: case DLL_THREAD_ATTACH: case DLL_THREAD_DETACH: case DLL_PROCESS_DETACH: break; } return TRUE; } #endif // XI_WIN
Replies (0)
