The values of use-stepdown and use-stepover in the input (str) are false.
But the values of them are changed to true after adsk.cam.ToolLibrary.createFromJson(str).
Why don't the values match? Is this a bug or feature? How to keep the value consistent?
str = '{"data": [{"BMC": "carbide", "description": "Keyseat Cutter - D3/8\\", reach 1.145\\"", "geometry": {"CSP": false, "DC": 0.375, "LB": 1.195, "LCF": 0.02, "NOF": 6.0, "OAL": 2.195, "SFDM": 0.375, "shoulder-length": 0.02, "HAND": true, "RE": 0.0, "tip-length": null, "assemblyGaugeLength": 1.0}, "guid": "12c02570-7bae-4c31-ab3b-b4f1ced3b482", "post-process": {"number": 0, "diameter-offset": 0, "length-offset": 0, "turret": 0, "comment": "", "manual-tool-change": false, "live": true, "break-control": false}, "type": "slot mill", "unit": "inches", "start-values": {"presets": [{"name": "AluWrought_Keyseat", "description": null, "guid": "49d714b5-c3a8-40c8-8957-34aabe94908a", "n": 10200.0, "v_f": 216.0, "v_c": 1001.382658331746, "f_z": 0.003529411764705882, "f_n": 9.80392156862745e-05, "n_ramp": 10200.0, "v_f_leadIn": 216.0, "v_f_leadOut": 216.0, "v_f_transition": 216.0, "v_f_retract": 180.0, "v_f_ramp": 216.0, "v_f_plunge": 60.0, "use-stepdown": false, "use-stepover": false, "stepdown": 0.0, "stepover": 0.0, "use-feed-per-revolution": false, "tool-coolant": "flood", "material": {"category": "all", "query": ""}}]}, "shaft": {"segments": [{"height": 1.125, "lower-diameter": 0.187, "upper-diameter": 0.187}, {"height": 0.05, "lower-diameter": 0.375, "upper-diameter": 0.375}], "type": "shaft"}, "holder": {"segments": [{"height": 0.148, "lower-diameter": 1.5, "upper-diameter": 1.97}, {"height": 0.836, "lower-diameter": 1.97, "upper-diameter": 1.97}, {"height": 0.176, "lower-diameter": 1.57, "upper-diameter": 1.57}, {"height": 0.09, "lower-diameter": 1.57, "upper-diameter": 1.75}, {"height": 0.425, "lower-diameter": 1.75, "upper-diameter": 1.75}, {"height": 0.05, "lower-diameter": 1.75, "upper-diameter": 1.85}, {"height": 0.03, "lower-diameter": 2.442, "upper-diameter": 2.502}, {"height": 0.145, "lower-diameter": 2.502, "upper-diameter": 2.502}, {"height": 0.079, "lower-diameter": 2.502, "upper-diameter": 2.215}, {"height": 0.118, "lower-diameter": 2.215, "upper-diameter": 2.215}, {"height": 0.079, "lower-diameter": 2.215, "upper-diameter": 2.502}, {"height": 0.143, "lower-diameter": 2.502, "upper-diameter": 2.502}, {"height": 0.03, "lower-diameter": 2.502, "upper-diameter": 2.442}, {"height": 0.125, "lower-diameter": 1.75, "upper-diameter": 1.75}], "type": "holder", "gaugeLength": 0.0, "guid": "2c36d80b-c99b-4673-a3f9-5d9ff60f2dc5", "unit": "inches"}}], "version": 0}'
toollib = adsk.cam.ToolLibrary.createFromJson(str)
tool = toollib[0]
tool.toJson()
'{"BMC":"carbide","GRADE":"Mill Generic","description":"Keyseat Cutter - D3/8\\", reach 1.145\\"","geometry":{"CSP":false,"DC":0.37499999999999994,"HAND":true,"LB":1.195,"LCF":0.02,"NOF":6,"NT":1,"OAL":2.195,"RE":0,"SFDM":0.37499999999999994,"TA":0,"TP":0,"assemblyGaugeLength":3.669,"shoulder-diameter":0.37499999999999994,"shoulder-length":0.02,"thread-profile-angle":60,"tip-diameter":0.37499999999999994,"tip-length":0,"tip-offset":0},"guid":"12c02570-7bae-4c31-ab3b-b4f1ced3b482","holder":{"description":"","gaugeLength":2.4739999999999998,"guid":"2c36d80b-c99b-4673-a3f9-5d9ff60f2dc5","product-id":"","product-link":"","segments":[{"height":0.148,"lower-diameter":1.5,"upper-diameter":1.97},{"height":0.836,"lower-diameter":1.97,"upper-diameter":1.97},{"height":0.176,"lower-diameter":1.57,"upper-diameter":1.57},{"height":0.09,"lower-diameter":1.57,"upper-diameter":1.75},{"height":0.425,"lower-diameter":1.75,"upper-diameter":1.75},{"height":0.05,"lower-diameter":1.75,"upper-diameter":1.85},{"height":0.03,"lower-diameter":2.442,"upper-diameter":2.502},{"height":0.145,"lower-diameter":2.502,"upper-diameter":2.502},{"height":0.079,"lower-diameter":2.502,"upper-diameter":2.215},{"height":0.118,"lower-diameter":2.215,"upper-diameter":2.215},{"height":0.079,"lower-diameter":2.215,"upper-diameter":2.502},{"height":0.143,"lower-diameter":2.502,"upper-diameter":2.502},{"height":0.03,"lower-diameter":2.502,"upper-diameter":2.442},{"height":0.125,"lower-diameter":1.75,"upper-diameter":1.75}],"type":"holder","unit":"inches","vendor":""},"post-process":{"break-control":false,"comment":"","diameter-offset":0,"length-offset":0,"live":true,"manual-tool-change":false,"number":0,"turret":0},"product-id":"","product-link":"","shaft":{"segments":[{"height":1.125,"lower-diameter":0.187,"upper-diameter":0.187},{"height":0.05,"lower-diameter":0.375,"upper-diameter":0.375}],"type":"shaft"},"start-values":{"presets":[{"description":"","f_n":0.0058823529411764705,"f_z":0.0035294117647058825,"guid":"49d714b5-c3a8-40c8-8957-34aabe94908a","material":{"category":"all","query":"","use-hardness":false},"n":10200,"n_ramp":10200,"name":"AluWrought_Keyseat","ramp-angle":2,"stepdown":0,"stepover":0,"tool-coolant":"flood","use-stepdown":true,"use-stepover":true,"v_c":1001.3826583317464,"v_f":216,"v_f_leadIn":216,"v_f_leadOut":216,"v_f_plunge":60,"v_f_ramp":216,"v_f_transition":216}]},"type":"slot mill","unit":"inches","vendor":""}'
