Bug when using the cam.GenerateAllToolpaths(False) Function
Joshua.mursic
Message 1 of 23
Joshua.mursic
Hello, when using the function below
I am getting an issue where all of the toolpaths regenerate, but some of them say that they are invalid.
I tried doing a loop and generating each operation one at a time but the same issue occurred, only worse.
cam:adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
        for operation in setup.operations:
            cam.generateToolpath(operation)
If I do the generate all toolpaths manually by selecting them all and Ctrl+G, this does not happen and they all calculate correctly. Is this a bug? Is there a better way to make sure all of my toolpaths are recalculated?
Replies (22)
Message 21 of 23
kandennti
@Joshua.mursic -San.
I'm glad you were able to solve the problem.
I forgot to mention that I was able to reproduce the same situation.
@jeff.pek -San.
It would be useful if the createFromCAMTemplate method had an optional parameter whether or not to start the calculation automatically.
Message 22 of 23
jeff.pek
Yes, that would be a good thing to support. We'll get it on the list.
I was able to track down exactly why this is happening:
When the script calls "generateAllToolpaths", it will try to abort any in-process generations. However, it doesn't wait around for the abort to actually happens, and the subsequent attempt to generate does not happen because one is already in progress.
You can get it to correctly process the regeneration by sleeping the script long enough (on my machine, about 7 seconds) before calling generateAllToolpaths, but that's obviously not a good solution.
We really need to do something to allow you to only create the operations (from a template or otherwise), and then keep control of when the regeneration happens.
Hope you can get by with this option setting for now. Unfortunately, there's no way to set the preference from a script 😞
Jeff
Message 23 of 23
Joshua.mursic
No problem! I have that workaround with the preferences. I appreciate all the help @jeff.pek  and @kandennti
