Bug report: args.command.helpFile does not work because of spaces in the path
OceanHydroAU
Message 1 of 1
OceanHydroAU
This is the only variation that does work (on Mac OSX):
cmd = args.command
cmd.helpFile = '/tmp/help.html' # Works!
Everything else fails every time (crashes or shows the (i) icon but the (i) icon does nothing when clicked) - I've tried (and these all exist)
'help.html'
'./help.html'
'resources/help.html'
'.//help.html'
'./resources/help.html'
'.//resources//help.html'
"'help.html'" # crashes fusion 360
'"./help.html"' # crashes fusion 360
'/Users/cnd/Library/Application Support/Autodesk/Autodesk Fusion 360/API/AddIns/Airfoil Tools/help.html'
'///Users/cnd/Library/Application%20Support/Autodesk/Autodesk%20Fusion%20360/API/AddIns/Airfoil%20Tools/help.html' # crashes fusion 360
'/Users/cnd/Library/Application%20Support/Autodesk/Autodesk%20Fusion%20360/API/AddIns/Airfoil%20Tools/help.html'  # crashes fusion 360
and
$ mkdir "/tmp/subfolder with spaces"
$ cp /tmp/help.html "/tmp/subfolder with spaces"
$ dir "/tmp/subfolder with spaces/help.html"
-rw-r--r--@ 1 cnd wheel 932 21 Apr 01:27 /tmp/subfolder with spaces/help.html
"/tmp/subfolder with spaces/help.html"  # fails
That last one is the smoking gun...
Should be an easy fix at least 🙂
Replies (0)
