Bug: Large contents in command dialog blanks dialog in sketch mode
thomasa88
thomasa88
If I create a command window in sketch mode and show more contents than can fit in the window, both the texts of the window and the controls of the sketch windows are blanked. I noticed this when working with a smaller Fusion window as I had other windows on the side.
If I make the Fusion window larger (or the textbox smaller):
Here is a minimal example add-in. Make the Fusion window small or increase the number of lines in the textbox. Create a new sketch and choose CREATE -> Run command.
from .lib import fusionAddInUtils as futil
import adsk.core
from datetime import datetime
app = adsk.core.Application.get()
ui = app.userInterface
def run(context):
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        # commands.start()
        cmd = ui.commandDefinitions.addButtonDefinition('bug_run_cmd', 'Run command', '')
        ui.allToolbarPanels.itemById('SketchCreatePanel').controls.addCommand(cmd)
        futil.add_handler(cmd.commandCreated, cmd_created)
    except:
        futil.handle_error('run')
def cmd_created(args: adsk.core.CommandCreatedEventArgs):
    inputs = args.command.commandInputs
    inputs.addTextBoxCommandInput('txt', 'Textbox', 'text', 20, False)
def stop(context):
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        # commands.stop()
        cmd = ui.commandDefinitions.itemById('bug_run_cmd')
        if cmd:
            ui.allToolbarPanels.itemById('SketchCreatePanel').controls.itemById('bug_run_cmd').deleteMe()
            cmd.deleteMe()
    except:
        futil.handle_error('stop')
BrianEkins
I can reproduce this, but I wonder how big of a problem it is. The only way I could reproduce it was to have the height of my Fusion window very small, which I doubt anyone uses for actual design work. Is there a particular use case where this is causing you problems?
Brian Ekins
thomasa88
I hit the problem when developing an add-in. I took me a while to figure out what was going on and realize that this particular add-in's code was not buggy. But as you say, the use case of a small window is not very likely when doing 3d design.
thomasa88
Update: It happened on my laptop too, with fullscreen. 1920x1080, 125 % scaling. Probably not a common scenario at a desktop workstation, but it can appear for quick on-the-go model changes on a laptop.
