[BUG?] Cannot get tooltip from commandDefinition
tykapl.breuil
tykapl.breuil
Title is pretty self explanatory, setting a commandDefinition's tooltip works fine but getting it only returns an empty string. I have tested this on two different computers and I have had the same problem.
I have this problem for both custom and native commandDefinitions. Here is a sample code for the Extrude command, am I the only one with this problem ?
If this problem can be reproduced, how you I go about properly reporting this bug ? (is a forum post enough ?)
Sample Code :
import adsk.core, adsk.fusion, traceback, adsk.cam
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
def run(context):
    try:
        extrude = ui.commandDefinitions.itemById('Extrude')
        if extrude.tooltip:
            ui.messageBox(extrude.tooltip)
        else:
            ui.messageBox('empty string')
        extrude.tooltip = 'test'
        if extrude.tooltip:
        else:
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @tykapl.breuil .
I tried it, and sure enough, the tooltip was empty.
I tried all the CommandDefinitions, and some of them seem to be able to get tooltips.
# Fusion360API Python script
import traceback
import adsk.cam
import adsk.fusion
import adsk.core
def run(context):
    ui = None
    try:
        ui: adsk.core.UserInterface = app.userInterface
        for cmdDef in ui.commandDefinitions:
            try:
                tooltip = cmdDef.tooltip
            except:
                continue
            if len(tooltip) > 0:
                app.log(f'ID:{cmdDef.id} - {tooltip}')
    except:
        if ui:
However, it doesn't change the fact that it's not working correctly.
tykapl.breuil
Checked your code and it's quite weird as the commandDefinitions for which it does work are seemingly random, apart from the fact that there seems to be most of the cad commands.
