BRepSurface Coordinate System
capuanbm
capuanbm
Hi all,
I'm working on a program and i'm trying to get the surface normals for a set of points. I know the points have a Z range of 80mm  - 116mm. When I do a bounding box on on my selected faces, i get the following range:
Min/Max   X Y Z
min-1.84881-1.207747.49332
max0.3743360.16694412.0113
Here's my code:
std::vector<Ptr<BRepFace>> faces;
faces.push_back(ui->selectEntity("Select face", "SolidFaces")->entity());
std::ofstream boudingBox("D:\\temp\\boundingbox.txt");
for (int k = 0; k < 2; k++)
	boudingBox << faces[k]->boundingBox()->minPoint()->x() << "," << faces[k]->boundingBox()->minPoint()->y() << "," << faces[k]->boundingBox()->minPoint()->z() << std::endl;
	boudingBox << faces[k]->boundingBox()->maxPoint()->x() << "," << faces[k]->boundingBox()->maxPoint()->y() << "," << faces[k]->boundingBox()->maxPoint()->z() << std::endl;
boudingBox.flush();
boudingBox.close();
I must be missing something, like how do i get the wcs for the face, so that i can change my input points to the correct wcs
note:
i'm using WCS (work coordinate system) as an abbreviation for the coordinate system of the face.
Thanks in advance for any help.
-Ben
capuanbm
Figured it out, the api units are CM, i need to divide the coordinates of my points by 10...
