Body physical property with VeryHighCalculationAccuracy
yamamoto.mas
yamamoto.mas
I'm trying to get moment of inertia of bodies as precisely as possible.
But the following getPhysicalProperties makes AttributeError:
Is there any other way to get precise physical properties of body ?
I'm using the following code which gives me properties with low precision.
import adsk.core, adsk.fusion, traceback
def spacePadRight(value, length):
    pad = ''
    if type(value) is str:
        paddingLength = length - len(value) + 1
    else:
        paddingLength = length - value + 1
    while paddingLength > 0:
        pad += ' '
        paddingLength -= 1
    return str(value) + pad
def walkThrough(bom):
    mStr = ''
    for item in bom:
        mStr += spacePadRight(item['name'], 15) + spacePadRight(item['i1'], 10) + spacePadRight(item['i2'], 10) + str(item['i3']) + '\n'
        mStr += spacePadRight(item['name'], 15) + spacePadRight(item['rx'], 10) + spacePadRight(item['ry'], 10) + str(item['rz']) + '\n'
    return mStr
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        title = 'Extract Primitive'
        if not design:
            ui.messageBox('No active design', title)
            return
        # Get all occurrences in the root component of the active design
        root = design.rootComponent
        occs = root.allOccurrences
        # Gather information about each unique component
        bom = []
        occ = occs[0]
        comp = occ.component
        bodies = comp.bRepBodies
        for bodyK in bodies:
            if bodyK.isSolid:
                physicalProperties = bodyK.physicalProperties
                # physicalProperties = bodyK.getPhysicalProperties(adsk.fusion.CalculationAccuracy.VeryHighCalculationAccuracy)
                (retVal, i1, i2, i3) = physicalProperties.getPrincipalMomentsOfInertia()
                (retVal, rx, ry, rz) = physicalProperties.getRotationToPrincipal()
                # Add this component to the BOM
                bom.append({
                    'name': bodyK.name,
                    'i1': round(i1,3),
                    'i2': round(i2,3),
                    'i3': round(i3,3),
                    'rx': round(rx,3),
                    'ry': round(ry,3),
                    'rz': round(rz,3),
        msg = walkThrough(bom)
        ui.messageBox(msg, 'Bill Of Materials')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
OceanHydroAU
Perhaps do not use round()?
AttribueError sounds like a bug you can fix though?
yamamoto.mas
Thanks for a comment.
This program is just for displaying data on the UI dialog.
In reality, another function calculates the body's shape and orientation with the assumption that the body is a cuboid. If I can get higher precision physical properties, I can get better estimation...
BrianEkins
Unfortunately, there appears to be an oversight in the design of the API.  The BRepBody object only supports the physicalProperties property and this doesn't let you define the accuracy.  It should also support the getPhysicalProperties method like some other objects do.  I've reported this to Autodesk and hopefully it's addressed soon.
Brian Ekins
