Best Way to Test if 2 points are coincident?
dirktheeng
dirktheeng
So, I need to test if 2 sketchPoints lay on top of eachother in a sketch.  Say the sketch points are sp1 and sp2
First, I make a point 3d object
p1 = sp1.geometry
p2 = sp2.geometry
Then compare the cooridnates
is |p1.x - p2.x| < smallNumber and |p1.y - p2.y| < smallNumber
The question is how small does small number have to be?  Or is there an entirely better way of doing this?
21st Century Woodworking
-Blending 21st Century Woodworking with Old World Skill
KrisKaplan
The easiest way to do this would be to use Point3D's isEqualTo method.
equal = sp1.geometry.isEqualTo(sp2.geometry)
This will use the modeler's default system tolerance (which is 1e-6).  This is the tolerance that we would use to test for any general point equality.  If you want to use some other tolerance, you can use the distanceTo method.
equal = sp1.geometry.distanceTo(sp2.geometry) <= myTol
Kris
Kris Kaplan
I try the following coding ,but this is error
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        root = design.rootComponent
        sketches = root.sketches
        sketch = sketches.add(root.xYConstructionPlane)
        sketchPoints = sketch.sketchPoints
        a1 = adsk.core.Point3D.create(1, 1, 1)
        a2 = adsk.core.Point3D.create(0, 3, 0)
        sketchPoint1 = sketchPoints.add(a1)
        sketchPoint2 = sketchPoints.add(a2)
        sp1 = sketchPoint1.geometry
        sp2 = sketchPoint2.geometry
        print (equal)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
could you tell me why, and how to improve it
BrianEkins
The reason for the failure is that you're getting the Point3D object from the sketch point using the geometry property an assigning it so sp1 and sp2 and then in the following line you're trying to call the geometry property on sp1 and sp2 but they're Point3D objects and don't have a geometry property.  Just change this line:
to this:
equal = sp1.isEqualTo(sp2)
Brian Ekins
