Message 1 of 1
automatic set Z tool axis for side drill depending of wcs orientation
Hi
I think I have build something really useful for my workflow (maybe a little confusing, but I am not a programmer).
This script search for a specific machining of a side drill and set automatically the Z axis for the tool.
The problem is that still does not work 100%. I have one case scenario with components mirrored and arranged where the script measure wrong the angle from the face normal to the wcs x axis (PI radians, 180 degree) and set in the opposite direction the Z axis
Can someone test it if can reproduce the glitch and help me to solve it? For try it naturally you need to change the name of the operation in the script or in the manifacture section of your model. It require a setup and a drill operation to work.
import adsk.core, adsk.cam, traceback, os
def run(context):
ui = None
try:
app = adsk.core.Application.get()
doc = app.activeDocument
products = doc.products
design = app.activeProduct
if not design:
ui.messageBox('No active Fusion design', 'No Design')
return
# Get the CAM product
cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
# List of all setups
setups = cam.setups
for setup in setups:
#keep model in the setup
setupBodies=setup.models
#check and count programs already exist
ops=setup.operations
opsNum=ops.count
if setupBodies.count>0:
setupFirstBody=setupBodies.item(0)
(origin, xAxis, yAxis, zAxis) = setup.workCoordinateSystem.getAsCoordinateSystem()
for op in ops:
opName=op.name
if opName.startswith('BORR 8 LEFT'):
opToolOrient0=op.parameters.itemByName('overrideToolView')
opToolOrient0.expression="true"
opToolOrient1=op.parameters.itemByName('view_orientation_mode')
opToolOrient1.expression="'axesZX'"
opToolOrientZ=op.parameters.itemByName('view_orientation_axisZ')
opToolOrientZ.expression="true"
firstBody=setupFirstBody
facesModel=firstBody.faces
#transBody=firstBody.transform
#transMatrix=transBody.asMatrix()
searchEdge=True
rak=0
rakMax=facesModel.count
while searchEdge and rak<=rakMax:
faceModel=[]
faceModel=facesModel.item(rak)
rak=rak+1
facePlane=faceModel.geometry
if facePlane.objectType=="adsk::core::Plane":
faceNormal=facePlane.normal
if xAxis.isParallelTo(faceNormal):
newZ=faceModel
cadObjectParam=[]
cadObjectParam: adsk.cam.CadObjectParameterValue = opToolOrientZ.value
opZ=cadObjectParam.value
opZ=newZ
cadObjectParam.value = [opZ]
angleZs=abs(xAxis.angleTo(faceNormal))
if angleZs>1:
op.parameters.itemByName('view_orientation_flipZ').expression='false'
else:
op.parameters.itemByName('view_orientation_flipZ').expression='true'
searchEdge=False
#axis=cadObjectParam.value
#axixAxiss.assign(xAxis)
#if newZ.isValid:
#regen operation of the setup
cam.generateToolpath(op)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
