Autocad Plant 3D Isometrics
Within Plant 3D Spec editor, for stud bolts, the numbers for stud diameters and lengths read corerctly, Example, 1 1/4"x17"
but when the iso is printed there is a period appearing in the BOM, and the numbers for the studs now read, 1.1/4"x17".
How do I correct this BOM output if the specifications read correctly?
Thanks Bill
ekinsb
Hi Bill,
This forum is for Fusion 360 programming questions.  I think you'll have better luck finding someone that is able to help you in the AutoCAD Plant 3D forum. http://forums.autodesk.com/t5/autocad-plant-3d-general/bd-p/371
Brian Ekins
Mod the Machine blog
