API manual: Sketch.offset method retired, use the createOffsetInput and addOffset2 methods
karl.ri
karl.ri
I cannot find any information about createOffsetinput and addOffset2.
My problem: I found no solution to get an "always outside" offset after a sketch.offset of a projected body.
So I hope addOffset2 will do it.
Regards from Austria,
Karl
Jorge_Jaramillo
You can find the documentation about them here:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-52c4f765-43c8-4d81-a1a8-5151dc02c03c
Regarding the offset direction (internal or external), there is a specification provided in the GeometricConstraints.createOffsetInput's offset parameter.
Jorge Jaramillo
karl.ri
Thanks Jorge for your promt reply.
I experimented a lot but cannot get it to work. See my problem in SOM.jpg:
code line 125 and 126: both lines and line  > isValid =True
code line 127: curves > isValid =  False (i have no idea, why)
geometricConstraints.createOffsetInput(curves, offset) generates the shown type error.
If I use the old version
 offsetcurv = skt.offset(curves, dirPoints, offset)
it works, but some of the offset lines are inside (see SOM2.jpg)
What I am doing wrong, any idea?
Karl
BrianEkins
Can you attach the design so that I can reproduce the problem and see if I can get the correct result?
Brian Ekins
karl.ri
Here is my design.
https://a360.co/3zDk3PJ
I am doing wooden puzzles and to minimize the usage of expensive wood in the milling process, I built an Add-Inn called SketchOffsetMove. I move the parts manually using the offset lines to snap to the nearest possible distance.
