API -import machine simulation file
ben
ben
Hi all,
Does the Fusion API have a command to import machine simulation files?
thanks & regards,
Ben
RohitMane_
Hello @ben ,
I might’ve misunderstood what you meant, but I think we can import a .mch or .f3d file with this command. Please let me know if you're looking for something else.
machineInput = adsk.cam.MachineFromFileInput.create(filePath)
# machineInput.ignoreSimulationModel = False
just make sure the filePath is expected to be an absolute path to the machine file on disk.
ben
Hi Rohit,
Thank you for your help. My main goal is actually to protect the machine simulation files. I want to set up the machine simulation for the customer and then input it into Fusion via the API. However, it seems that machine simulation files cannot be imported across hubs — they must first be manually uploaded to my own hub. Is there any solution to this?
Ben
