API - feature request - access to "avoid/machine surfaces" groups
maurizio_manzi
maurizio_manzi
Please see attached pic.
We urgently need a way to add groups via the API, change the "machineMode", and add surfaces. Additionally, we need to be able to modify the values in the "radial" and "axial" fields.
Currently, the parameters have the same names, regardless of which row they belong to.
Best regards
Maurizio
csinger
Das wäre wirklich sehr hilfreich!!!
christina_kehle
Sehr wichtig.
boopathi.sivakumar
Hi @maurizio_manzi@christina_kehle @csinger
Here is the sample how you can use  Machine avoid  https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a0cfe144-1a0f-4109-9125-8fbd3176ceed
look for the createMachineAvoidGroup function that should cover everything you are looking for
Boopathi Sivakumar
Senior Technology Consultant
maurizio_manzi
Thank you very much
maurizio_manzi
in this example are only the mutually groups in use:
# Get the MachineAvoidGroups object from the CadFaceGroups cad object. This object manages the list of mutually exclusive groups.
        _machineAvoidGroups = surfaceGroupsParam.getMachineAvoidGroups()
 Neither in the example nor in the API documentation could I find how to change the mode for the groups automatically inserted by Fusion.
Best regards
Maurizio
