API: Create a sketch on a surface of a body
Hi Everyone,
I am fairly new to programming Fusion 360 via python. I want to create a sketch on a surface of a body. From this sketch I want to extrude a geometry as a new body. The code is underneath.
I have two issues:
1) How do I know the index of the face I want to create the sketch on (body.faces.item(???))
2) I get following error when I run the program. Does anybody know what it means? It is connected to the "start_from"-object.
Thanks for any help
Sören
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Create a document.
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
# Get the root component of the active design
rootComp = design.rootComponent
# Create a new sketch on the xy plane.
sketches = rootComp.sketches;
xyPlane = rootComp.xYConstructionPlane
sketch = sketches.add(xyPlane)
# Draw a rectangle by two points.
dimRec=25
lines = sketch.sketchCurves.sketchLines;
recLines = lines.addCenterPointRectangle(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(dimRec/2, dimRec/2, 0))
prof =sketch.profiles.item(0)
# Draw a second rectangle by two points.
dimRec=0.2
lines1 = sketch.sketchCurves.sketchLines;
recLines1 = lines1.addCenterPointRectangle(adsk.core.Point3D.create(2, 2, 0), adsk.core.Point3D.create(dimRec/2, dimRec/2, 0))
profRec1=sketch.profiles.item(0)
# Create distance value inputs
mm10 = adsk.core.ValueInput.createByString("10 mm")
#Get extrude features
features = rootComp.features
extrudes = features.extrudeFeatures
extInput = extrudes.createInput(prof,adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
extInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(0.8))
extFront = extrudes.add(extInput)
bodyFront=extFront.bodies.item(0)
bodyFront.name= "Frontplatte"
# Create an extrusion that starts from an entity and goes the specified distance.
extInput0 = extrudes.createInput(profRec1, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
# Create a distance extent definition
extent_distance_2 = adsk.fusion.DistanceExtentDefinition.create(mm10)
# Create a start extent that starts from a brep face with an offset of 10 mm.
start_from = adsk.fusion.FromEntityStartDefinition.create(bodyFront.faces.item(0), mm10)
# taperAngle should be 0 because extrude start face is not a planar face in this case
extInput0.setOneSideExtent(extent_distance_2, adsk.fusion.ExtentDirections.PositiveExtentDirection)
extInput0.startExtent = start_from
# Create the extrusion
extrude3 = extrudes.add(extInput0)
body3 = extrude3.bodies.item(0)
body3.name = "Connector"
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Hi There, I see there are a couple of views and no answers: Can you give me a hint about If there is anything wrong with the post? Code too long, solution too obvious? Or am I too unpatient 🙂
Yours Sören
kandennti
Hi soeren.bergmann
I am also studying, so I can not write code well. Therefore, I write only the idea.
The 'BRepFace' object has a 'tempId' property.
The 'BRepBody' object has a 'findByTempId' method, which allows you to find a surface from the ID.
However, I do not know the numbering rule of 'tempId'....
It may be necessary to search by geometry processing.
I think that it is good to make extrudeFeature by using ConstructionPlane.
kandennti
After carefully examining the 'ExtrudeFeature' object, there was an 'endFaces' property.
opposite the start faces could be acquired with this.
        #start_from = adsk.fusion.FromEntityStartDefinition.create(bodyFront.faces.item(0), mm10)
        endsurf = extFront.endFaces
        start_from = adsk.fusion.FromEntityStartDefinition.create(endsurf.item(0), mm10)
I also learned a lot.
Hi kandennti,
thanks that you looked into the problem. I replaced the start_from... line with your solutions. When I run the script I still get the error message I posted initially. Did you get the error-message with the original code?
Sören
kandennti
I ran it with this code.
(Win 10 + Fusion 360ver 2.0 423)
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        dimRec=25
        dimRec=0.2
    except:
        if ui:
OK, thats interesting. I didn't get a error message, that's good. I also got rid of the offset, now the thing is, that the extrude is the negative of the one I want to gain. Means, I want to have a small cube on front of the bigger plate. But I will look into that, thanks for your support, this got me much further. When I have time I will compare it more closely with my original code because I still not understand what caused the error message. And I still not exactly understand how I can access any surface I want, e.g. when I want to make a sketch on the thin sides of the plate I wouldn't know how to access it either.
Cheers!
Sören
